You can use a Veritas Wonder Pup anywhere you can drill a 19mm hole. Veritas Wonder Pups are basically bench dogs with a length of threaded bar through the top, with a swivel handle at one end and brass clamping face at the other. The Wonder Pups have a 70mm long stem fitted with an O-ring, which slightly raises the threaded bar just above the bench surface for easier adjustment. The projection above the bench is only 16mm. The Wonder Pup stem, drilled and tapped with at 3
Veritas
Veritas Wonder Pups
| Web Attribute Set | Bench Dogs & Bench Fittings |
