This specially designed dozuki saw blade easily clips into the handle of our Small Dozuki Saw. It has sturdy teeth and a fine 21tpi pitch. These robust and sharp teeth are perfect for cutting intricate and precise joints in hardwoods. The special tooth grind enables cross, rip and mitre cuts with equal precision.
Zet Saw
Z-Saw Blade for Japanese Small Dozuki Panel Saw - Hardwood 150mm
| Blade Thickness | 0.30 mm |
| Tooth Pitch \ tpi | 1.21 mm \ 21 tpi |
| Length of Blade | 150 mm |
| Saw Blade Type | Crosscut |
| Web Attribute Set | Japanese Back Saws |
| EAN Barcode | 4963041071063 |
