The KNIPEX Zinc Plated High Leverage Concreter's Nippers are designed to offer substantially higher cutting performance and ergonomic advantages. These nippers feature a damping of the cutting stroke after cutting the binding wire, reducing strain on tendons and muscles. They can twist and cut wire in one operation, making them fast, reliable, and economical.
Made from special tool steel that has been oil-hardened and tempered, these nippers have an extra-slim form, making them ideal for tying submerged positioned steel rods. They provide a particularly high cutting capacity with minimum effort due to their optimum transmission ratio. The high damping of the cutting stroke after cutting the binding wire further enhances user comfort.
Overall Length: 250mm (10in)
Wire Cutting Capacities: Hard: 1.8mm; Medium: 3.3mm
Head Width: 25mm
Weight: 350g
Length 300 mm
Web Attribute Set Concrete & Cement Tools
EAN Barcode 4003773033080
