12 piece parallel punch and chisel set for a wide range of applications. Punches are made from heavy-duty chrome-vanadium steel. Contains the following: 3 x Cold Chisels: 10, 12, 16mm.6 x Parallel Pin Punches: 1.5, 3, 4, 5, 6, 8mm.1 x Taper Punch: 2mm.2 x Centre Punches: 6, 8mm.
Roughneck
Roughneck Punch & Chisel Set 12 Piece
| Web Attribute Set | Punches - Nail & Parallel |
| EAN Barcode | 25997311809 |
