The Right Angle Clamp with Automaxx® Auto-Adjust Technology makes pocket hole assembly fast, accurate, and secure. Start by inserting the hardened steel pin into a pocket hole, which anchors one workpiece firmly against the other for easy alignment. The arm opposite the pin features a swivel pad that adjusts to sit tight against your material, ensuring solid, shift free clamping.
With a simple squeeze of the handles, Automaxx® technology automatically adjusts the clamp to the material thickness, providing consistent pressure so you can clamp thin drawer sides and 1/2 plywood, to thick 2x4 boards for cabinetry, furniture, and outdoor projects. There is a thumbwheel for easy clamping pressure changes. The ultra wide opening allows versatile use, and you can use one clamp for small projects or two for larger assemblies to maintain precise alignment while driving pocket-hole screws.
Web Attribute Set Quick Clamps
EAN Barcode 647096806088
