For anyone wishing to try their hand at carving, or need to carve now and again, this set fits the bill perfectly. This set contains five chisels, well chosen with a range of commonly used profiles. Each has a hardened carbon steel blade ground and sharpened, only slight honing may be required before use. The handles are natural beech wood, with a rounded ‘squarish’ section to prevent them rolling off your bench.
The set also includes a blank of lime wood to get you started and sharpening instructions
Chisels: Skew chisel with flat bevel, Shallow Gouge, Medium Gouge, Deep Gouge and Vee tool.
Quality tools made in Europe.
Set 5 Piece
EAN Barcode 8590137692008
