This Faithfull Paint Mixing Paddle has an 8mm hexagon shank and is recommended for use in power drills of at least 400W; use the lowest gear and slow speed for best results. It will thoroughly mix paint, epoxy resin, paste, tile adhesives, levelling compounds etc. The overall length is 400mm; the basket is 60mm diameter and suitable for mixing 2.5 to 10 litres.
Faithfull
Faithfull Mixing Paddle 60 x 400mm
| Web Attribute Set | Plastering Tools and Sundries |
| EAN Barcode | 5023969262994 |
