The DEWALT 18V XR 300mm Brushless Compact Chainsaw (Body Only) is a powerful and efficient tool designed to handle most woodcutting applications with ease. This chainsaw is perfect for both professionals and DIY enthusiasts who need a reliable and compact tool for their cutting needs.
It features an 18V brushless motor, providing high efficiency to complete most woodcutting applications. The 300mm/30cm 3/8”LP bar and chain are ideal for cutting wood up to 250 mm in diameter, making it versatile for various tasks. With the ability to make up to 100 cuts per charge (using the DCB184 battery, sold separately), this chainsaw offers extended use on a single charge.
The tooled chain tensioning system ensures reliable bar clamping, reducing maintenance times and keeping the chainsaw in optimal condition. On-board tool storage allows the wrench to be conveniently stored on the tool for quick in-field adjustments. The compact design of the chainsaw makes it easy to store and transport, while the ergonomic handles provide comfort in multiple positions, reducing user fatigue.
The visible oil tank gauge makes it easy to check the oil level before starting work, ensuring the chainsaw is always ready for use. For added safety, the chain brake stops the chain in under 1 second when activated. Bumper spikes grip the material while cutting, providing greater control over the application.
Supplied as body only without batteries and charger. Part of the 18V XR battery system, ensuring compatibility with over 250 other 18V tools
Includes
1 x 18V XR Brushless Compact Chainsaw
1 x 3/8”LP 30cm Bar (DT20665)
1 x 3/8”LP 30cm Chain (DT20676)
1 x Wrench
1 x 4.0mm File
3-year manufactures guarantee applies, subject to registration.
Battery Voltage 18 V
Battery Type Li-ion
Web Attribute Set Cordless Chainsaws
EAN Barcode 5035048838501
