The DeWALT DCMPS567N Extending Brushless Pole Saw 18V (Body Only) is a meticulously engineered tool designed to make pruning and limbing tasks easier and more efficient. This pole saw features a high-efficiency brushless motor that delivers up to 55 cuts on 100mm diameter branches, ensuring powerful performance and long-lasting durability. With an impressive reach of up to 4.5 metres when using the extension pole, this tool allows you to tackle high branches and tough jobs with ease.
The DeWALT DCMPS567N Extending Brushless Pole Saw is designed with an angled head, providing a more controlled position when limbing and felling. This ergonomic tool is lightweight, well-balanced, and sturdy, making it easy to maneuver even at its fully extended length. Made from light aluminium tubing, it weighs just 4.5kg if used with a 5.0Ah 18V XR battery, reducing user fatigue during extended use.
The pole saw is equipped with a 20cm low kickback bar and chain, featuring auto-oiling for smooth cutting performance. The metal bucking strips and tree hook offer a durable cutting grip and make it easy to remove pruned branches. Additionally, the 18V 5.0Ah XR batteries provide extended runtime, ensuring you can complete your tasks without frequent recharging.
Supplied as body only without batteries and charger. Part of the 18V XR battery system, ensuring compatibility with over 250 other 18V tools.
3-year manufactures guarantee applies, subject to registration.
Battery Voltage 18 V
Battery Type Li-ion
Web Attribute Set Cordless Chainsaws
EAN Barcode 5035048713624
