The AP25BM is a robust, compact bench mounted chisel morticer, produced almost entirely from cast iron. This strong, heavy-duty construction gives the machine capacities of 25mm in softwood and 19mm in hardwood. A single handwheel controls both longitudinal and lateral table movement. This system makes controlling the movement a breeze. The table has a tall back fence, with lateral stops for repeat mortising. The depth stop includes a haunch stop. The multiple position material clamp can accommodate different workpiece widths. A gas strut provides smooth downward travel of the headstock and also allows headstock parking in any position. There is an optional floor stand, plus also a very useful door mortising attachment.
This machine is well suited to a busy workshop and will provide many years of accurate and trouble-free service. It accepts chisels with either 3/4 or 13/16 shanks.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 460 mm x 515 mm x 1,000 mm
Power 750 W
Rating Frequent Use
Plug Fitted UK 3 pin plug
Web Attribute Set Morticers
EAN Barcode 5052511124800
  • UK Mainland - £70
