This set of Kirschen bevel edge chisels is a fine example of a time when chisel makers took care to ensure that the handle was matched to the blade width. In this case the 4 chisels are fitted with graduated white beech handles. Each well shaped handle is fitted with a steel ferrule and hoop to prevent splitting. The blades are fully polished front and back and produced from Kirschen's own high carbon steel. When honed these chisels hold an excellent edge. The set comprises 10, 16, 20 and 26mm widths.
Web Attribute Set Chisel Sets
