All the features to fulfil the needs of the keen craft woodturner
If you’re new to woodturning and short on space, the Perform PD205WL Woodturning Lathe is a great place to start. Designed with beginners in mind, it is compact and easy to store. Featuring a sturdy cast iron build, simple variable speed control, centres and more, this lathe has everything you need to get started. Ideal for small projects like pens, bottle stoppers and pepper mills.
Conveniently compact
Weighing just 20kg and perfectly compact, the PD205WL is easy to transport and ideal for smaller workshops.
Variable speed drive
One of our favourite features of this lathe is the ability to move smoothly, quickly and conveniently through the speed controls.
Stable build
The cast iron construction ensures stability and reliability. The bed is made from cast iron, helping to reduce vibration.
Two centres included
The lathe is supplied with the Perform 4 Prong 1MT Drive Centre and the Perform 1MT Live Centre, designed and manufactured in Axminster, UK.
Tool rest
Also supplied with a 175mm tool rest for added versatility.
Perfect for...
The PD205WL is ideal for beginner or entry level turning. Make small projects like pens, light pulls and bowls. Despite its size, this lathe still has plenty of power in the motor.
Want to learn more?
Discover the joy of woodturning from home! Our Woodturning for Beginners course teaches you the essentials - safety, sharpening, and turning techniques—while guiding you through two fun, step-by-step projects. Or  not sure if this lathe is right for you? Read our blog for more information.
Explore our Courses
If you're keen to learn the art of woodturning, this beginner lathe could be the answer.
The PD205WL is a compact and portable woodturning lathe, perfect for beginners or those with limited workshop space. It offers a range of versatile features suited to small-scale projects such as pen turning, bottle stoppers, pepper mills, and other craft items, and pairs perfectly with the Perform Woodturning Chuck for added convenience and precision.
It's capacity makes it ideal for turning goblets, boxes and bowls up to 200mm in diameter. The lathe's variable speed control allows for precise adjustments, while the motor power ensures consistent performance across a range of projects.
Constructed from machined cast iron, the PD205WL offers stability and smooth operation. Its durable build ensures trouble free operation and years of minimal maintenance. Supplied with a 175mm tool rest, Perform 4 Prong 1MT Centre and Perform 1MT Live Centre. It's ready to support a variety of small turning tasks and is the perfect woodturning lathe for beginners or light use.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 730 mm x 150 mm x 310 mm
Power 300 W
Rating Occasional Use
Plug Fitted UK 3 pin plug
Web Attribute Set Woodturning Lathes
EAN Barcode 5052511142248
