This is a great kit to accompany your Festool plunge saw, It can also be used with all plunge saws, routers or insulation saws.
The kit contains guide rails with adhesive pads, joiners, clamps and a strong padded storage bag to protect everything when in transit and storage.
The 1,400mm guide rails have two underside neoprene strips to reduce slippage and but can also be used with the adhesive pads which offer an alternative method of increasing the security of your guide rail on a wide range of different surfaces, as well as holding the rail vertically.
Rail joiners ensure a positive and perfect alignment of the rails. Rail clamps are supplied for when you need more security that just the neoprene anti slip strips on the underside of the rail, but when adhesive pads may not be suitable to use.
The strong padded rail bag also has a extra pocket for accessories and gives protection for 2 rails up to 1,400mm in length, fitted with a carry strap idea for transport and storage.
Supplied with 2 x 1,400mm guide rails, adhesive pads, 2 x FSZ screw rail clamps, 2 x FSV/2 connectors and padded rail bag.
Manufacturer Part Number 577932
EAN Barcode 4014549431962
