This high performance blade delivers fast and accurate cuts in heavy-duty applications. It has a thin kerf, only 2.16mm, requiring far less power for a given cut. The kerf and 305mm diameter make it perfectly suited for cutting larger, thicker timber. The 7
DeWalt
DeWALT Extreme Runtime Saw Blade - 305mm x 2.16mm x 30mm 78T
| Blade Diameter | 305 mm |
| Maximum RPM | 4,800 rpm |
| Additional Accessories | No |
| Kerf | 2.16 mm |
| Teeth | 78 |
| Tooth Format | ATBR |
| Plate Thickness | 1.6 mm |
| Hook Angle | 7 |
| Bore Size | 30 mm |
| Web Attribute Set | Circular Saw Blades |
| EAN Barcode | 5035048542385 |
