The Bosch 10.8V/12V is perfect for cutting laminate flooring and similar, this compact circular saw gives a powerful cut in wood up to maximum depth of 26.5mm at 90 and 17mm at 45. The base is adjustable for depth and has an angle scale. The thin kerf TCT blade draws less power from the machine with less waste than a thicker kerf blade to ensure quick progress through the material.
Supplied as a body only so that you can utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality for the best possible battery life and runtime; tool and battery talk to each other as fitted with electronic cell protection (ECP).
Utilise batteries from the other tools in the family. Bosch Li-Ion battery technology is premium quality for the best possible battery life and runtime; tool and battery talk to each other as they are fitted with electronic cell protection (ECP).
Supplied as body only and Parallel guide/guide rail adapter that can be used to guide the tool or used with a Bosch guide rail.
N.B. Bosch Professional are changing the product name of 10.8V power tools, batteries and chargers to 12V. All Bosch Professional 12V tools are 100% compatible with all current (10.8V) Bosch Professional power tools, batteries and chargers. All 10.8V and 12V tools can be used within the same voltage class system.
Battery Voltage 12 V
Max Depth of Cut @ 45º 17 mm
Max Depth of Cut @ 90º 26.5 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 85 mm
Sound Power Level LwA [Uncertainty K] 101 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 90 dB(A) [3.0 dB]
Saw Blade Speed 1,400 rpm
Web Attribute Set Cordless Circular Saws
EAN Barcode 3165140755849
