The DeWALT DCS391 Premium Circular Saw delivers powerful performance and exceptional control, thanks to its intelligent trigger design that ensures precision across all applications. Its high‑efficiency PM58 fan‑cooled motor, equipped with replaceable brushes, produces up to 3,700 RPM for fast, smooth cutting. A built‑in spindle lock allows quick and easy blade changes. Tool free fast depth and bevel setting; 55mm at 90 degrees and 42mm at 45 degrees, while the adjustable bevel feature offers angles up to 50° for greater flexibility.
Engineered for durability, the saw features a cast magnesium base that supports repetitive, accurate cuts. The ergonomic handle with rubber overmold provides excellent comfort during extended use. This cordless circular saw is an ideal solution for trimming wood panels, chipboard, and other sheet materials.
Supplied with a 165mm x 24 tooth 16mm bore TCT carbide blade, rip fence, dust extraction port and hex key as standard.
Supplied as body only (no battery or charger).
Part of the DeWALT 18V Li-ion XR battery family taking standard XR and Powerstack Batteries.
Specifications
No‑Load Speed: 5,150 rpm
Max Cutting Depth @ 90° = 55 mm
Max Cutting Depth @ 45° = 42 mm
Blade Size: 165 mm diameter, 20 mm bore
Weight: 3.8 kg
Battery Voltage 18 V
Max Depth of Cut @ 45º 42 mm
Max Depth of Cut @ 90º 55 mm
Blade Diameter 165 mm
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Circular Saws
EAN Barcode 5035048356210
