The DEWALT DCS570 XR Brushless Circular Saw is designed for versatile, everyday cutting tasks—including ripping, cross‑cutting, and bevelling across timber and a wide range of construction materials. Powered by a high‑torque brushless motor, it delivers increased durability, efficiency, and consistent performance for demanding site work and precision joinery.
A clear cutting-depth scale allows accurate settings up to 65mm at 90 degrees and 49mm at 45 degrees, while the adjustable bevel feature offers angles up to 57° for greater flexibility. Fitted with a Bright LED for improved cut line visibility and built in blower. Its robust, stable block construction minimises vibration for smoother operation and extended tool life. An additional front handle ensures secure, controlled, two‑handed use. Direct compatibility with Dewalt Airlock system dust extractors. Supplied with 184mm 24tooth TCT Sawblade, rip fence and dust extraction port.
Supplied as body only (no battery or charger).
Part of the Dewalt 18v Li-ion XR battery family taking standard XR and Powerstack Batteries.
Specifications:
No‑Load Speed: 5,500 rpm
Max Cutting Depth @ 90°: 64mm
Blade Size: 184mm (16mm bore)
Bevel Capacity: 57°
Battery Voltage 18 V
Max Depth of Cut @ 45º 49 mm
Max Depth of Cut @ 90º 64 mm
Blade Diameter 184 mm
Battery Type Li-ion
Corded or Cordless Cordless
Saw Blade Speed 5,500 rpm
Web Attribute Set Cordless Circular Saws
EAN Barcode 5035048663110
