This thoughtfully designed 190mm saw allows you to cut to a maximum of 66mm. It has a 1,200W high specification and powerful motor. The flat motor housing lets the saw stand upright and stable when changing the blade. The heavy-duty base, cut from aluminium plate, forms a solid base adding to the overall quality. Depth adjustment simplified using a single action lever. The rubber moulded grip greatly increases comfort when in use. The guarding is die-cast aluminium.
This product is manufactured in the UK, at the Makita factory in Telford.
