The Einhell TP-CD 18/120 Li-i BL-Solo Power X-Change Combi Drill is powered by an Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. Once you register online, the brushless motor has a 10-year warranty. With its impact drilling function, it supports professional craftsman when working on resistant materials such as stone or concrete.
In addition, the impact drill has a 2-speed gearbox which allows fast screwing, drilling and powerful impact drilling. The torque-slip clutch prevents screws from being overtightened. The hard torque of 120Nm is adjustable over 21 torque levels. The impact drill/driver also offers a drilling stage and an impact drilling stage. The infinitely variable speed electronics support application and material appropriate work.
The single-sleeve 13mm metal quick-release chuck made of metal with locking function allows a quick and easy change of the tool. Safe and wrist-friendly operation is ensured by the additional handle with softgrip. The LED light provides a good view of the work area even in poor visibility. For safe storage, the impact drill can be easily attached to the belt with the belt clip.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Drill Chuck: 13mm Single Sleeve.
No Load Speed: 500/2,100/min.
Impact Rate: 6,500/27,300/bpm.
Max. Torque: 120Nm.
Torque Settings: 21 + 1 + 1 Settings.
Weight: 1.71kg.
Battery Voltage 18 V
Reverse No
Sound Power Level LwA [Uncertainty K] 102 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 1.5 mm to 13 mm
Sound Pressure Level LpA [Uncertainty K] 94 dB(A) [3.0 dB]
Web Attribute Set Cordless Combi Drills
EAN Barcode 4006825672336
