The Einhell TP‑CD 18/80 Li‑i BL Power X‑Change Combi Drill is a high‑performance, versatile tool designed for demanding drilling, screwdriving and impact drilling applications. Its advanced PurePOWER brushless motor delivers increased power, longer runtime and superior durability compared to traditional carbon‑brush motors. When registered online, the brushless motor is protected by a 10‑year warranty, offering long‑term confidence and reliability.
Built to handle tough materials such as stone and concrete, the combi drill features an impact drilling function and a robust 2‑speed gearbox. It delivers 8,000 impacts per minute in first gear and up to 28,800 in second gear for fast, efficient drilling performance. An adjustable torque-slip clutch prevents overtightening, while the 80 Nm hard torque can be precisely controlled across 20 torque settings. Infinitely adjustable speed electronics ensure smooth, material‑appropriate working across all applications.
Specifications
Drill Chuck: 13mm single sleeve
No Load Speed: 0–500 / 0–1,800 min⁻¹
Impact Rate: 0–8,000 / 0–28,800 bpm
Max Torque: 80 Nm
Torque Settings: 22
Weight: 1.44 kg
For user comfort and convenience, the drill includes a quick‑stop function and a durable 13mm metal single‑sleeve quick‑release chuck with locking mechanism for fast bit changes. The Softgrip auxiliary handle reduces strain on the wrists during heavy-duty use, and the integrated LED light illuminates the work area for better visibility. A belt clip offers secure temporary storage while working at height or on the move.
As part of the Power X‑Change family, the TP‑CD 18/80 Li‑i BL is fully compatible with all batteries and chargers in the series. A 3‑year Einhell warranty is included with registration within 30 days.
The included 4.0Ah battery features Einhell’s 7‑in‑1 ABS Active Battery Management System and a 3‑stage LED charge indicator. The integrated microprocessor constantly monitors key parameters such as temperature and voltage to ensure optimal performance and safety. A repair mode enables deeply discharged batteries to be reactivated, prolonging their service life. Premium quality Li‑ion cells offer low self‑discharge, and the rubber‑coated housing provides excellent impact protection and grip. The ergonomic recessed handle ensures comfortable handling during battery changes.
The compact, efficient 3A charger reduces downtime with fast charging technology and includes built‑in mounting loops for easy wall installation. Its intelligent charging management system monitors the battery throughout the process, ensuring safe and consistent charging. It also features a refresh mode for recovering deeply discharged batteries and a clear 6‑stage LED status display.
The E‑Case S‑F system case provides organised storage and convenient transport for the drill, battery, charger and accessories. Measuring 44 × 33 × 13 cm and capable of supporting up to 25 kg, the case is fully compatible with the modular Einhell E‑Case system. Constructed from durable polypropylene, it is impact‑resistant, splash‑proof and heat‑resistant. Secure stacking latches keep multiple cases firmly connected, and its design allows it to be opened even while stacked. Two foldable ergonomic handles ensure comfortable carrying, and an integrated locking point enables padlock security.
Supplied with a 18V 4.0Ah Power X‑Change Li‑Ion Battery, 3A Quick Charger and E‑Case S‑F.
Battery Voltage 18 V
Reverse No
Sound Power Level LwA [Uncertainty K] 98.7 dB(A) [5.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 13 mm
Sound Pressure Level LpA [Uncertainty K] 87.7 dB(A) [5.0 dB]
Web Attribute Set Cordless Combi Drills
EAN Barcode 5052511146567
