The Axminster Workshop AW18BDS Belt & Disc Sander 230V is ideal for detailing, shaping, and finish sanding for those larger projects. It features a 25 x 1,067mm belt and a 150 x 200mm tilting table for profiling and finishing. The 200mm disc abrasive and 190 x 270mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.
The machine includes two 38mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, and a mitre gauge. It's perfect for working on larger projects that may require a larger sanding capacity.
Please note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 840 m/min
Dust Extraction Outlet 32 mm I.D. / 38 mm O.D.
Overall L x W x H 520 mm x 470 mm x 510 mm
Power 550 W
Rating Regular Use
Abrasive Belt Size 25 mm x 1,067 mm
Plug Fitted UK 3 pin plug
Model AW18BDS
Abrasive Disc Diameter 200 mm
Nett Weight 24.5 kg
Table Size, Belt 150 mm x 200 mm
Table Size, Disc 190 mm x 270 mm
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511137343
