The Axminster Workshop AW18BDS Belt & Disc Sander 230V is ideal for detailing, shaping, and finish sanding for those larger projects. It features a 25 x 1,067mm belt and a 150 x 200mm tilting table for profiling and finishing. The 200mm disc abrasive and 190 x 270mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.
The machine includes two 38mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, and a mitre gauge. It's perfect for working on larger projects that may require a larger sanding capacity.
Please note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.
