A welcome addition to many small home workshops
This Axminster Workshop Belt & Disc Sander enables the shaping, sanding and profiling of wood to be carried out easily and safely.
Buy with confidence
Dust extraction port - AW200BDS
Efficient dust extraction
A fan built into the dust outlet makes extraction a breeze. When connected to an extractor, almost 100% of the dust can be removed.
Multi belt position - AW200BDS
Multi belt position
The belt sanding platen can be positioned vertically, horizontally or at any angle in between.
Sand compounds and mitres - AW200BDS
Both the belt and disc tables incorporate a slot for the mitre fence, allowing bevel and compound angle sanding. Both sanding functions have a well-sized work table, which pivots from 0° to 45°.
Quiet running motor - AW200BDS
Quiet running
Both the belt and disc are driven directly from the 550W induction motor, making it quieter than a drive belt system.
Machine guarding - AW200BDS
Excellent guarding
Well fitting guarding not only makes this a safe machine to use but also helps improve dust extraction.
Cast iron body - AW200BDS
Cast iron body for minimal vibration
The main body is cast iron helping to reduce vibration for a more comfortable woodworking experience.
The AW200BDS is a powerful combined 100mm belt and 200mm disc sander. The belt and the disc are driven directly from the motor spindle. As a consequence the machine is much quieter, there are no fiddly drive belts to worry about and does not suffer from a loss of power caused by a drive belt. Both functions feature cast worktables, which pivot from 0° to 45°. A mitre fence is supplied for bevel and compound angle sanding.
The belt sanding platen can be used vertically or horizontally or anywhere in between. The machine has a 63mm extraction outlet. A powered fan in the dust outlet port helps produce an airflow around both the belt and disc. When connected to a suitable vacuum extractor almost 100% dust extraction can be achieved. The main body is cast iron, which absorbs vibration and has locating holes with rubber grommets for securing this sander to a workbench.
The AW200BDS is supplied with a belt and hook and loop abrasive disc. There is a wide selection of abrasive belts and discs available.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 520 m/min
Dust Extraction Outlet 63 mm
Overall L x W x H 590 mm x 520 mm x 380 mm
Power 550 W
Rating Regular Use
Abrasive Belt Size 100 mm x 915 mm
Plug Fitted UK 3 pin plug
Model AW200BDS
Abrasive Disc Diameter 200 mm
Disc Speed 2,980 rpm
Nett Weight 26 kg
Table Size, Belt 170 mm x 120 mm
Table Size, Disc 264 mm x 190 mm
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511125319
