A versatile addition to any small home workshop
This Perform Belt & Disc Sander enables shaping, sanding and profiling to be carried out easily and safely on wood.
A yellow and black Perform 150 belt sander sits on a wooden workbench shelf, with a yellow Perform extractor visible on the right against a grey cinderblock wall.
Compact design
Easy to store when not in use, the compact design makes the sander ideal for those with smaller workspaces.
A person using a yellow and black PERFORM belt sander to smooth a piece of wood on a workbench, with a dust collector hose connected on the left.
Strong, robust construction
A heavily constructed chassis is constructed in a single iron casting; this supports the belt arm and tables. There are also locating holes for securing the sander to a workbench, if desired.
A yellow and blackbelt and disc sander with a dust collector hose attached, being used by a person to sand a round wooden disc on a workbench.
Compounds and mitres
The table features a mitre slot for bevel and compound angle sanding. Both sanding functions use a decent size worktable which tilts to 45°.
A person using a yellow and black belt sander to smooth the corner of a light-colored wooden block on a workbench.
Multi belt position
The belt sanding plate can be positioned vertically or horizontally.
A close-up of a yellow and black PERFORM sanding machine with a white table top, showing a person's hand holding a sanding sheet against the belt sander, with a clear dust collector hose connected on a wooden workbench.
Hook and loop
Hook and loop velcro discs are used to make disc changes easy and quick. It also saves adhesive residue being left on the machine.
A close-up of a yellow and black Perform belt sander with a clear corrugated dust collection hose connected to its side, set on a wooden workbench.
Safeguard your health
The belt is fitted with close fitting guarding to help with efficient dust extraction for safeguarding health. Simply connect your belt and disc sander to a suitable vacuum extractor via the 63mm dust port to achieve almost 100% extraction.
The right grit makes all the difference
From rough shaping to a fine finish, having the right abrasive for each stage makes your projects look their best. Explore our selection and find the perfect grits for your work.
Learn more about abrasives
The Perform PD150BDS Belt & Disc Sander is a compact and neatly designed, light use sander. It features a 100mm x 915mm belt and a 150mm disc. The belt sanding platen can be used vertically or horizontally. The worktable can be used for either function, and tilts up to 45. The mitre fence allows easy bevel and compound angle sanding.
The machine has close fitting guarding and a 63mm dust extraction outlet. When connected to a suitable vacuum extractor, it offers almost total dust extraction. The main body of the machine is a single cast iron therefore is strong and stable. It has locating holes for securing the sander to a workbench.
The PD150BDS makes an ideal beginner sander or for those simply using it for light use for shaping, sanding and profiling. There is a selection of hook and loop abrasive belts and discs available for various applications.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 550 m/min
Dust Extraction Outlet 58 mm I.D. / 63 mm O.D.
Overall L x W x H 470 x 370 x 295 mm
Power 370 W
Rating Occasional Use
Abrasive Belt Size 100 mm x 915 mm
Plug Fitted UK 3 pin plug
Model PD150BDS
Abrasive Disc Diameter 150 mm
Disc Speed 2,980 rpm
Nett Weight 21 kg
Table Size, Belt 216 x 146 mm
Table Size, Disc 216 x 146 mm
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142125
Accessories
  • Axminster Abrasive Belts 100 x 915mm (Pkt 5) - Mixed
  • Axminster Quick Release 63mm Hose Fixing Clip (Pkt 2)
  • Perform PD50E 50L Wood Dust Collector 230V
  • Axminster EU Power Cable - C19 - 2m
  • Axminster VC Abrasive Disc - 150mm
