This machine will make the jointing process simple. It is compact, light in weight and well thought out with adjustable fences and clear scales. It plunges smoothly in vertical, horizontal or angled work faces. The fence is clearly marked so you can line up the cut. It has a tilting base with quick locking lever and positive stops at 0, 45 and 90
Makita
Makita PJ7000 Biscuit Jointer
| Dust Collection | Dust Bag Supplied |
| Blade Diameter | 100 mm |
| Sound Power Level LwA [Uncertainty K] | 97 dB(A) [3.0 dB] |
| Corded or Cordless | Corded |
| Sound Pressure Level LpA [Uncertainty K] | 86 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Motor Power | 700 W |
| Cutter Speed | 10,000 rpm |
| Voltage | 230 V |
| Web Attribute Set | Biscuit Jointers |
