The Makita VC3012M Wet & Dry Dust Extractor is a powerful, professional‑grade solution for effective dust control in workshops and on-site environments. Designed for both general clean‑up and direct connection to power tools, it delivers strong, reliable extraction while supporting a cleaner and safer working environment.
Powered by a robust 1500W Makita motor, this extractor produces impressive suction of up to 250 mbar, making it highly effective at capturing fine and hazardous dusts. With a certified Dust Class M rating, it meets EU standards for the extraction of harmful dust such as hardwood and MDF, giving added confidence when working with demanding materials. The durable 30 litre plastic tank provides ample capacity for extended use, reducing interruptions while remaining compact and easy to manoeuvre.
For efficient, tool‑integrated dust extraction, the VC3012M features an automatic start/stop power take‑off that activates the extractor as soon as a connected power tool is switched on. This improves dust capture at source and helps maintain a tidy workspace. The Push & Clean semi‑automatic filter cleaning system enables quick maintenance at the press of a button, helping to maintain airflow and prolong filter life. Capable of both wet and dry extraction, this versatile Makita dust extractor is well suited to professional tradespeople and serious workshop users alike.
Makita is a globally respected manufacturer known for producing high‑quality power tools and dust management solutions built for durability and performance. With a strong focus on reliability, safety and user comfort, Makita products are trusted by professionals worldwide.
Supplied with a 4.0m vacuum hose with a 32mm diameter, an integrated power tool take‑off socket, a built‑in M‑class filter with manual cleaning system, a tough 30 litre plastic tank and a 7.5m power cable to provide excellent working reach.
Overall L x W x H 450 × 380 × 595 mm
Corded or Cordless Corded
Cable Length 7.5 m
Max Capacity Dry 24 litre
Airflow Volume 3,700 litre/min
Sound Pressure Level LpA [Uncertainty K] 62 dB(A)
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Web Attribute Set Power Tool Extractors
EAN Barcode 88381829458
