The Einhell TE-CN 18 Li-Solo Power X-Change Nailer and narrow Stapler is perfect for your garage or workshop and renovation work. Fixing objects with staples or nails is easy with stapler-nail gun combo. The robust gearbox allows up to 20 impacts/min., while depth adjustment ensures variable impact depth. Working close to edges is possible thanks to the slim stapler nose.
The magazine has a level indicator providing an overview of the current load and maximum capacity of 100 nails or clamps, all securely held by a magnet. It can be easily opened and refilled at the push of a button. The pressure mechanism on the stapler nose allows safe working, while large softgrip surfaces offer comfortable and firm hold.
Supplied with practical belt clip for safe storage and 300 nails (32mm) + 300 staples (19mm). With the supplied hexagon key, nail/staple jams can be easily and quickly fixed. Release protection prevents unintentional tacking/nailing, preventing injury.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Supplied as body only (no battery or charger).
Specifications:
Shots per Minute: 20.
Staple Length: 16-22mm.
Staple Width: 5.7mm.
Nail Length: 15-32mm.
Nail Thickness: 1mm.
Magazine Capacity: 100.
Weight: 2.07kg.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Web Attribute Set Cordless Nailers & Staplers
EAN Barcode 4006825653786
