The Einhell TP‑RO 18 Li BL Router/Palm Router Kit combines power, precision, and cordless convenience—ideal for detailed woodworking, edge trimming, and shaping tasks. Powered by Einhell’s PurePOWER brushless motor, it delivers increased performance, longer runtime, and superior durability compared to traditional brushed motors. Registering the tool online also extends the motor warranty to 10 years, giving long‑term peace of mind.
With its variable speed control (10,000–30,000/min), the router adapts effortlessly to different materials, from softwood to hardwood. Cutting depth is infinitely adjustable and includes a fine‑adjustment feature for highly accurate routing results, supported by a multi‑setting turret stop for repeatable depth changes. A precise twin‑tube guide ensures smooth, controlled operation, while the spindle lock allows quick and easy bit changes. The router is compatible with 1/4, 6mm, and 8mm collets, giving flexibility for a range of cutter sizes up to 30mm in diameter.
Work areas remain clearly visible thanks to the integrated LED light, and a protective plastic insert helps prevent damage to delicate surfaces. The ergonomic soft‑grip handle ensures comfortable, secure handling, while the chip shield improves visibility and safety by deflecting debris. For added precision on larger tasks, a two‑handed attachment provides increased stability, and the included edge‑trimmer base allows clean, consistent beveling.
The kit comes supplied with everything needed to get started: 1/4 collet sleeve, 6mm and 8mm collets, a parallel stop, compass tip, copy sleeve, assembly tool, extraction adapter for Einhell wet & dry vacuums, and a durable storage bag for easy transport and protection. As part of the Power X‑Change family, the tool is compatible with all batteries from the range and includes a 3‑year Einhell warranty with registration within 30 days.
Also included is an Einhell Power X‑Change 18V 2.5Ah Li‑ion Battery and Power X‑Fastcharger. The battery features Einhell’s advanced 7‑in‑1 ABS Active Battery Management System, using a microprocessor to monitor temperature, voltage, and overall battery health. Even deeply discharged batteries can be revived using repair mode. High‑quality Li‑ion cells ensure long lifespan with minimal self‑discharge, and the rubber‑coated housing provides excellent shock resistance and grip. A recessed handle and 3‑step LED charge indicator enhance usability.
The 4A Power X‑Fastcharger reduces downtime with rapid charging technology and continuously monitors the battery for optimal safety and performance. Its refresh mode restores heavily discharged batteries, while a 6‑stage LED display provides clear, up‑to‑date charging information. Integrated suspension eyelets allow convenient wall mounting.
Specifications:
Collet Diameter: 1/4, 6mm & 8mm
Speed Range: 10,000–30,000/min
Lift Height (Edge Router Attachment): 40mm
Lift Height (Router Attachment): 35mm
Max. Shape Cutter: 30mm
Suction Adapter Diameter: 35mm
Battery Voltage 18 V
Dust Extraction Outlet 35 mm
Sound Power Level LwA [Uncertainty K] 91.4 dB(A) [3.0 dB]
Batteries Included 2
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 80.4 dB(A) [3.0 dB]
Cutter Speed 10,000 - 30,000 rpm
Web Attribute Set Routers
EAN Barcode 5052511146512
