Narex
Narex Spoon Carving 3 Piece Set
SKU: 109465
€75,00
  • Make something highly decorative or simply practical
  • Includes 3 of the most useful spoon carving tools
  • Plus a roughly cut blank of European Lime
  • Manganese-vanadium steel blades 60-62 HRC
  • Blank size 255mm x 55mm x 30mm
  • An absorbing branch of wood carving
The Narex spoon-carving set contains everything you need to make a start on this absorbing branch of wood carving. Spoon carving requires just a few tools and the results can be highly decorative or plain and practical.
This set from Narex includes three of the most useful spoon carving tools plus a roughly cut blank of European Lime to get you started right away. Lime is easy to carve with hand tools and takes fine detail.
The tools include: a Double-edge Hook Knife, which can be used right or left handed, a 20mm Spoon Gouge with a No.6 sweep and a Detail Carving Knife with a 40mm blade. The tools are made of manganese-vanadium steel, refined to a hardened and tempered to 60-62 HRC, and will take and hold an excellent edge. The handles are dyed European beech.
Blank size 255mm x 55mm x 30mm.
Web Attribute Set Carving Tool Sets
EAN Barcode 8590137698000
