Great value for woodturners and cabinet makers alike
The AP2920B Bandsaw represents a fantastic capacity machine that can serve those with limited space perfectly. It’s a professional grade machine with features to suit both woodworkers and turners.
Buy with confidence
Large cast iron table
The 440mm x 540mm table gives maximum support to large workpieces that will glide smoothly on the cast iron.
Tubular steel frame & press steel doors
The AP2920B is built on a tubular steel frame for robust strength and reduced vibration.
Independent adjustable blade guide system
Set up quickly and easily, so you can focus on the task at hand.
300mm depth of cut
300mm depth of cut
A generous depth of cut makes this bandsaw versatile enough for a variety of tasks, from cabinet making to woodturning preparation.
Cast iron blade wheels
355mm diameter cast iron wheels reduce vibration and maintain blade speed for a smooth and consistent cut.
Dual slots for mitre gauge
Two mitre slots either side of the blade are perfect for jig use. The AP2920B is supplied with a premium mitre fence with useful pre-set angle stops.
Rack & pinion upper guide adjustment
Easily adjust the upper blade guide with the rack and pinion rise and fall. There is also a tension release lever for straightforward blade changes.
Hi/lo auxiliary rip fence
The dual height rip fence locks positively; use “hi” for full support on heavy duty ripping and “lo” for safe close to the blade work.
High quality handwheels
The bandsaw’s hand wheels are well made in die cast aluminium for smooth adjustment.
A close-up of a bandsaw cutting a sheet of material over a wooden surface, with the AXCALIBER brand name and a British Made badge visible on the image.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Professional by name, professional by nature. The AP2920B floor standing bandsaw represents great value, whether in a busy workshop or for a woodworker looking for a larger capacity machine. The 1.7kW induction motor easily copes with the 300mm max cutting height. The 355mm diameter cast iron wheels with hard rubber tyres, add to the smooth cutting action.
The smooth ground, cast iron table tilts up to 45 and features mitre fence slots on both sides of the blade. The upper blade guide has rack and pinion rise and fall for ease of adjustment.
The rip fence locks positively and has a Hi/Lo auxiliary fence. ‘Hi’ for full support when deep ripping or ‘Lo’ when cutting thin section timber.
The quick tension release makes blade changing straightforward. Fully adjustable blade tensioning and tracking ensure precise cutting action.
Dual dust extraction is efficient via a 63mm outlet under the table linked to a 100mm outlet by the bottom wheel.
Supplied with a premium mitre fence with useful pre-set angle stops. Also supplied with blade - 2,920mm x 12mm x 6tpi.
Please note, if you require an EU plug, please ensure you purchase 113776
Dust Extraction Outlet 100 mm & 63 mm
Overall L x W x H 760 mm x 875 mm x 1,910 mm
Power 1.7 kW
Rating Frequent Use
Table Height 1,015 mm
Table Size 440 mm x 540 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 1,200 m³/hr
Sound Power Level LwA [Uncertainty K] 90 dB(A) [3.0 dB]
Sound Pressure Level LpA [Uncertainty K] 72.5 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Model AP2920B
Bandsaw Blade Length 2,920 mm (115")
Bandsaw Wheel Diameter 355 mm
Blade Speed 800 m/min
Blade Width Min\Max 3 mm to 19 mm
Max Cutting Height 300 mm
Max Width of Cut 345 mm
Nett Weight 122 kg
Table Height on Stand N/A
Voltage 230 V
EAN Barcode 5052511127535
  • UK Mainland - £70
