If you have ever wanted to take up woodturning, this lathe will meet all your needs and provide hours of turning enjoyment in your workshop. Its compact design and affordable price make it ideal for those with limited space or a tighter budget, and it pairs perfectly with the Perform Woodturning Chuck.
The AD240WL woodturning lathe features five spindle speeds, giving a useful range between 700 and 2,800rpm. It has a maximum bowl turning capacity of 240mm diameter and a spindle turning capacity of 440mm between centres.
The headstock, bed and tailstock are constructed of heavy cast iron, minimising vibration. The 375W induction motor has more than enough power for the lathe’s capacities and any projects that are likely to be undertaken. Both the headstock spindle and tailstock barrel take 2MT accessories, with the spindle nose having a 1 x 8tpi thread. The tailstock also has a hollow barrel to enable long hole boring.
Supplied with Axminster drive and revolving tailstock centres, 75mm diameter faceplate and 150mm tool rest.
N.B. The distance between centres will vary slightly dependent on the type of centres or accessories used.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 900 mm x 205 mm x 365 mm
Power 375 W
Rating Regular Use
Model AD240WL
Distance Between Centres 440 mm
Headstock Taper 2 MT
Lathe Speed 700 - 2,800 rpm (5)
Max Diameter over Bed 240 mm
Nett Weight 38 kg
Spindle Thread 1 x 8 tpi
Tailstock Ram Travel 40 mm
Tailstock Taper 2 MT
Tool Post Diameter 16 mm (5/8)
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511125203
