Powerful performance in a compact, robust design
The smaller of the two table saws in the Axminster Workshop range, the AW216BTS is ideal for smaller cutting tasks, whether for craft projects or DIY jobs. With a robust design, precision ground cast iron table, quiet motor and impressive cutting capacity for its size, it's a reliable, hard-working addition to any workshop.
Buy with confidence
A person using an Axminster Workshop table saw to cut a piece of wood in a workshop setting. The table saw is white and silver with a black blade guard and a flexible grey dust collection hose.
Compact yet stable
The AW216BTS Table Saw is compact, making it ideal for cutting smaller pieces of timber with precision. Constructed from powder-coated steel, the sturdy leg design improves stability and provides a comfortable working height for greater control and ease of use.
Close-up of an Axminster Workshop table saw showing the control panel with red and yellow emergency stop buttons and a black handwheel.
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is reserved for much larger saws. This improves adjustability and allows for a much smoother blade rise and tilt function.
Axminster workshop table saw induction motor
Quiet induction motor
Powered by a quiet 1.1 kW induction motor, this saw is ideal for use in residential areas where noise is a concern.
A person using a table saw with a wood sheet in a workshop setting, with a flexible grey dust collector hose connected to the saw. The table saw is branded Axminster Workshop
Cutting capacity
It offers impressive cutting capacities, with a 60 mm depth at 90° and 40 mm at 45°, plus a maximum rip width of 345 mm. The 790 x 925 mm precision ground cast iron table includes left, right and rear extensions, while the full-length rip fence features a sliding high/low sub-fence for added versatility. The saw is supplied with an Axcaliber Premium TCT Saw Blade 216 x 2.2 x 30mm 48T.
A person using a red and white Workshop band saw to cut a light wood plank in a workshop setting with a blue dust collector hose connected.
Safety features
An NVR switch is included, with a separate lockable emergency stop function. This helps to protect users and the equipment from harm, providing quick shutdown when needed.
Gif showing the dust extraction on an Axminster Workshop table saw
Dust extraction
Keep the saw line clear with combined above-blade and below-table dust extraction, both feeding into a single outlet for easy connection to an extractor.
Get the best out of your AW216BTS
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Axminster Workshop AW216BTS Table Saw is an excellent, compact woodworking table saw for a home workshop, hobby woodworkers, DIY enthusiasts or for everyday woodworking tasks. Featuring a precision ground cast iron table, smooth chassis-mounted trunnion system and quiet 1.1kW induction motor, it delivers accurate cuts without taking up excessive workshop space. Slightly more compact than the AW254TS Table Saw, it is particularly well suited for cutting smaller timber pieces with precision, ideal for furniture projects and general woodworking tasks.
Powered by a quiet 1.1 kW induction motor, this saw is ideal for use in residential areas where noise is a concern. Its robust, precision ground cast iron table features 19 mm mitre fence T-slots on both sides of the blade, allowing workpieces to glide smoothly across the surface. Despite its compact size, it offers impressive cutting capacities: 60 mm depth at 90° and 40 mm at 45°, with a maximum rip width of 345 mm making it well suited to a wide variety of tasks. The table measures 790 x 925 mm and comes with left, right, and rear extensions for added versatility. The full-length rip fence includes a sliding sub-fence with high/low adjustment options.
The tilt and height adjustment mechanism and motor are bolted directly to the chassis rather than the underside of the table, ensuring exceptionally smooth operation without added stress from hanging components. This design provides precise, effortless adjustments, enabling a wide range of cuts for diverse woodworking applications.
Dust extraction on the AW216BTS Table Saw is highly efficient, combining above-blade and below-table extraction into a single port for connection to an extractor. Safety features include an NVR switch with a separate, lockable Emergency Stop function. Removable side panels make cleaning and maintenance quick and simple.
The sturdy stand features a compact leg design for stability, even when handling larger or heavier workpieces. Constructed from powder-coated steel, the stand raises the saw to a comfortable working height, and rubber feet keep it securely in place during use.
This compact table saw offers exceptional value while delivering impressive performance for its size. Ideal for home workshops, hobby woodworkers, furniture makers and DIY renovation projects, it's equally at home in a small professional workshop. Perfect for cutting smaller sheet materials and producing accurate rip cuts in both hardwood and softwood, it's a versatile addition to any workshop.
Supplied with an Axcaliber Premium TCT Saw Blade - 216mm x 2.2mm x 30mm 48T.
Please note, if you require an EU plug, please ensure you purchase 113504
Blade Tilt 0 to 45
Dust Extraction Outlet 94 mm I.D. / 98mm O.D. 63 mm
Max Depth of Cut @ 45º 40 mm
Max Depth of Cut @ 90º 60 mm
Max Width of Cut with Fence 345 mm
Overall L x W x H 960 x 1,100 x 1,070 mm
Power 1.1 kW
Rating Regular Use
T Slot Size 19 mm
Table Height 850 mm
Table Size 790 x 925 mm
Blade Diameter 216 mm
Min Extraction Airflow Required 1,000 m³/hr
Sound Power Level LwA [Uncertainty K] 95 dB(A)
Blade RPM 4,000 rpm
Sound Pressure Level LpA [Uncertainty K] 80 dB(A)
Plug Fitted UK 3 pin plug
Model AW216BTS
Bore Size 30 mm
Nett Weight 73 kg
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511144150
