A strong, versatile disc sander that won’t break the bank!
Perfect for any hobbyist’s workshop, the build quality and performance of this sander really does speak for itself when you see it in use.
Buy with confidence
Strong and sturdy design - AW300DS
The main body is cast iron which helps to reduce vibration for a more comfortable experience.
Plenty of power - AW300DS
Plenty of power
A quiet 750W induction motor provides ample power to handle your projects, while a disc brake and NVR switch safeguard you for complete peace of mind at all times.
Sand compounds and mitres - AW300DS
The table incorporates a mitre fence running in a slot, for bevel and compound angle sanding. Both sanding functions use a decent size work table which pivots from 0° to 45°. 
Dust extraction port - AW300DS
High levels of dust extraction
The disc is fitted with close fitting guarding, to help with efficient extraction for safeguarding health and better visibility whilst working. Plus, almost 100% dust extraction can be achieved when connected to a simple vacuum extractor.
Quiet running motor - AW300DS
Quiet running
The disc sander is driven by the quiet 750W induction motor, for enjoyable work.
Sanding wood - AW300DS
Perfect for…
This sander is ideal for outside curves, sanding to the line, smoothing wood and plastic, removing small waste material and prepping surfaces by removing old finishes.
The AW300DS has an 300mm diameter aluminium disc driven by a quiet 750W induction motor. It has a no-volt-release switch and a brake to slow the disc down in a reasonable time.
The cast iron sanding table has a ground top surface with a slot for the mitre fence. The unique mitre fence has two faces at 90 and can produce LH and RH 45 bevels without resetting. The table tilts up to 45 and firmly locks at both sides.
Efficient dust extraction is via a 63mm outlet. A 450mm length of flexible hose is provided with the machine for connection to a vacuum or similar extractor.
Overall, the AW300DS is solid, weighty and stable and does a good job when it comes to sanding to a line and similar tasks.
Self adhesive abrasive discs are available in a wide range of grits.
Tip: Self adhesive discs can easily be removed complete with their glue by gently warming with a hot air gun (or a simple hair drier) before removing.
Please note: these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 63 mm
Overall L x W x H 500 mm x 470 mm x 420 mm
Power 750 W
Rating Regular Use
Table Size 445 mm x 155 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 390 m³/hr
Plug Fitted UK 3 pin plug
Model AW300DS
Abrasive Disc Diameter 300 mm
Disc Speed 1,420 rpm
Nett Weight 30 kg
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511125388
