Reliable performance to support smoother, faster woodworking
This planer thicknesser brings together practical features that make every stage of your work easier. With a spiral cutter block for a cleaner finish, simple table lifting, clear digital adjustments, and a powerful motor, it's built to handle a wide range of tasks. Generous capacity and solid construction ensure dependable results, project after project.
Buy with confidence
Spiral cutter bloc - AW3310S
Spiral cutter block
Spiral cutters produce an incredibly smooth finish, with planing ripple virtually eliminated. This cutter block features 30 knives arranged in two rows, lasts many times longer than HSS blades, and is noticeably quieter in use. When an edge dulls, simply rotate the cutter 90̊ with the supplied Torx driver.
Single lift tables - AW3310S
Single lift tables
The tables are joined together and can be lifted in one motion, making it quicker to switch between jointing and thicknessing.
Digital height gauge - AW3310S
Quick and easy thickness adjustment ensures accurate cuts, every time.
3kW motor - AW3310S
3kW motor
Providing ample power, the 3kW motor can handle a wide range of tasks with ease.
Alloy fence - AW3310S
Alloy fence
The alloy fence provides reliable support for precise work and adjusts easily with stops at 90° and 45°.
Excellent capacity - AW3310S
Excellent capacity
With a 310mm planing width and 230mm thicknessing capacity, the AW3310S Spiral Planer Thicknesser allows you to tackle large projects efficiently.
Perfectly flat timber - Woodworking Wisdom Blog
Start every project with perfect stock
Discover how a planer thicknesser can elevate your projects.
Read our blog
The AW3310S Spiral Planer Thicknesser is engineered for smooth, accurate, and consistent results. Its spiral cutting block uses 30 knives arranged in two rows, offering a far longer service life than traditional HSS blades. With this design, planing ripple is virtually eliminated. When an edge eventually dulls, simply rotate the cutter 90° with the supplied Torx driver - tighten, and you’re back to work. There’s no resetting, no downtime, and no waiting for sharpened blades to return. Spiral blocks also run quieter and with significantly reduced vibration.
The alloy fence provides reliable support for precise work, and adjusts easily with stops at 90° and 45°. Switching between jointing and thicknessing is quick and intuitive thanks to the single-lift tables, which raise together in one smooth motion. A 5.4 m/min feed speed ensures a consistently clean, smooth finish.
Adjustments are straightforward: the digital height gauge makes adjustments simple, while a viewing window in the feed table allows easy monitoring during operation.
Powered by a robust 3 kW motor, the AW3310S Spiral Planer Thicknesser handles a wide range of tasks with its 310 mm planing width and 230 mm thicknessing capacity. The maximum depth of cut when planing is 3 mm, whilst the maximum depth of cut for thicknessing is 4 mm.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Dust Extraction Outlet 100 mm
Feed Speed 5.4 m/min
Knives TC Spur Cutters x 30
Overall L x W x H 1400 x 1200 x 1050 mm
Power 3.0 kW
Rating Regular Use
Min Extraction Airflow Required 1,500 m³/hr
Sound Power Level LwA [Uncertainty K] 87 dB(A) [3.0 dB]
Plug Fitted UK 16A Plug
Cutterblock Diameter 75 mm
Cutterblock Speed 4,500 rpm
Length of Table 1400 mm
Max Depth of Cut Planer 3.0 mm
Max Depth of Cut Thicknesser 4.0 mm
Max Planing Width 310 mm
Max Thicknessing Height 230 mm
Nett Weight 208 kg
Number of Knives 30
Number of Motors 1
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511142323
  • UK Mainland - £70
