The Fuji Spray Semi-Pro2 HVLP spray system features a powerful 1,400W 2-stage motor turbine and comes complete with a Fuji Spray M-Model 7002G gravity spray gun. The turbine unit is in a sturdy steel cabinet complete with a grab handle and handy gun storage. The external air filters are easy to wash or change. The Fuji Spray Semi-Pro2 includes a 7.6m hose with Quick Connect Coupler and an Air Control Valve. This is a lightweight machine ideally suited to serious DIY, crafts or hobbies.
The Fuji Spray M-Model 7002G gravity spray gun has a 400cc cup. The spray gun has an ergonomically designed, insulated handle that is very comfortable in use and insulates well against the heat that can develop in the handle of an HVLP spray gun. This gravity feed gun, being lighter and more manoeuvrable than the suction type guns, is a good choice for smaller projects or cabinet interiors. It comes with an air cap set #3 (1.3mm) installed.
The Fuji Spray Semi-Pro2 HVLP spray system is supplied with a comprehensive user manual, viscosity cup, cleaning brush and wrench.
Note: When spraying thick high gloss paints, the required thinning can affect the final finish. In this case we recommend using a 4 or 5 stage turbine unit; such as the Fuji Mini-Mite 4 or 5 or A Fuji Q4 or Q5 unit.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Overall L x W x H 305 mm x 218 mm x 206 mm
Rating Home/Light Trade
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [1.5 dB]
Motor Power 1,400 W
Plug Fitted UK 3 pin plug
Web Attribute Set HVLP Spray Systems
EAN Barcode 612850022035
