Axminster No. 5 1/2 Bedrock Jack Plane is a highly versatile bench plane suited to board flattening, panel truing, shooting board work and general stock preparation. Positioned between a traditional No. 5 and No. 6, it combines the manoeuvrability of a jack plane with the increased length, width and weight needed for more efficient flattening work. Equally at home in the workshop or on site, it is an excellent all-round choice for both enthusiasts and professionals.
The Bedrock-style design provides enhanced blade support and stability, helping to reduce chatter and improve surface finish. The plane features an adjustable frog, precise depth adjustment and lateral blade control, allowing fine tuning for a range of tasks. Its extra mass helps carry the plane smoothly through the cut, while the comfortable hardwood handles provide excellent control during extended use. The No. 5 1/2 is also particularly effective on a shooting board, where its size and weight help produce accurate, square edges.
The ductile iron body offers outstanding strength and durability, while the precision-ground sole measures 375mm long for reliable flattening performance. The plane is fitted with a premium 60mm (2⅜) wide, 3mm thick cryogenically treated high carbon steel blade, offering excellent edge retention. The blade is supplied with a 25° bevel and requires only minimal preparation before use. Solid brass fittings, including the cap iron and adjustment nut, ensure smooth and dependable adjustment.
Axminster woodworking tools are designed to deliver reliable performance, traditional craftsmanship and excellent value. Combining proven designs with quality materials, they provide woodworkers with tools they can depend on for years of service.
Ideal for furniture makers, cabinetmakers, joiners and serious woodworking enthusiasts, the Axminster No. 5 1/2 Bedrock Jack Plane is perfect for flattening boards, truing panels, shooting board work and general bench duties. Supplied ready for final honing and setup, it requires only minimal preparation before producing fine shavings.
Sole Length 375 mm
Web Attribute Set Hand Planes
EAN Barcode 5052511147229
