The Perform PD15BDS Belt & Disc Sander 230V is ideal for detailing, shaping, and finish sanding. It features a 25 x 762mm belt and a 145 x 145mm tilting table for profiling and finishing. The 125mm disc abrasive and 170 x 95mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.
The machine includes two 35mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, a mitre gauge and a support bolt. It's perfect for various beginner hobby and craft workshop applications and is especially suited to those with a smaller workspace.
Please note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 840 m/min
Dust Extraction Outlet 30 mm I.D. / 35 mm O.D.
Overall L x W x H 320mm x 340mm x 385mm
Power 250 W
Rating Occasional Use
Abrasive Belt Size 25 mm x 762 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Belt & Disc Sanding Machines
EAN Barcode 5052511142132
