If you're keen to learn the art of woodturning, this beginner lathe could be the answer.
The PD205WL is a compact and portable woodturning lathe, perfect for beginners or those with limited workshop space. It offers a range of versatile features suited to small-scale projects such as pen turning, bottle stoppers, pepper mills, and other craft items, and pairs perfectly with the Perform Woodturning Chuck for added convenience and precision.
It's capacity makes it ideal for turning goblets, boxes and bowls up to 200mm in diameter. The lathe's variable speed control allows for precise adjustments, while the motor power ensures consistent performance across a range of projects.
Constructed from machined cast iron, the PD205WL offers stability and smooth operation. Its durable build ensures trouble free operation and years of minimal maintenance. Supplied with a 175mm tool rest, Perform 4 Prong 1MT Centre and Perform 1MT Live Centre. It's ready to support a variety of small turning tasks and is the perfect woodturning lathe for beginners or light use.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 730 mm x 150 mm x 310 mm
Power 300 W
Rating Occasional Use
Plug Fitted UK 3 pin plug
Web Attribute Set Woodturning Lathes
EAN Barcode 5052511142248
