An excellent starter table saw with versatile cutting power
Perfect for beginners, the PD254TS Saw Bench is a fantastic first table saw. It’s designed to handle a variety of timber sizes and makes different types of cuts easy. With handy features like soft start, blade tilt, and cast aluminium tables, it’s a great choice for woodworking crafts, and all kinds of DIY projects.
A yellow and silver PERFORM table saw with a white blade guard, set up on a wooden workbench in a workshop environment with a red tool chest and workshop tools in the background.
Strong and sturdy
The 560 x 680 mm strong coated cast aluminium table gives a solid space to work on and ensures for smooth cutting. The rigid table insert prevents collapsing when cutting.
A yellow and black Perforum  table saw in a workshop setting, with a person's hand guiding a piece of wood through the blade. A mitre gauge is attached to the table saw, and various tools hang on the wall in the background.
Soft start
The soft start feature ensures that the motor powers up gradually, making the saw more user-friendly, especially in shared or residential environments.
A person wearing red ear protection guides a light wood board across a yellow and silver table saw in a workshop setting.
Powerful motor
The high powered 2000W motor maintains blade speed for a consistent cut.
A close-up of a person's hands guiding a piece of wood under a table saw with a clear safety guard and red fence on a grey table saw surface.
Mitre and rip fence included
The mitre fence allows you to produce accurate crosscuts at any angle. The dual locking rip fence ensures that it is super rigid for accurate cuts.
A person's arm and hand guide a light-coloured plywood sheet across a table saw with a mitre gauge attached, in a workshop setting.
Cutting capacity
The saw boasts an impressive 80mm cutting depth and a 650mm width capacity, thanks to its extendable side table. This makes it easy to handle larger pieces of wood.
A close-up of a table saw blade entry area with a clear plastic guard, black adjustment knob, yellow blade, and red safety insert on a gray table surface.
Blade tilt
The blade tilts from 90 to 45 degrees so you can achieve a range of different cuts including mitred, rip cuts and crosscuts in both man-made and natural timbers.
A close-up of a table saw with a silver metal table, a bright yellow circular blade, and a black and yellow PERFORM brand guide. A clear plastic guard is attached above the blade, and the background shows a workshop setting.
Quality blades
Two Teflon coated blades are included which help to prevent resin build-up; a 24-tooth ripping blade and a 60-tooth crosscut blade.
A close-up of a table saw with a visible circular blade and guide rail, showing a person's hand pointing to the push stick stored in a handy location on the saw
Push stick included
A push stick is included for safe working as well as integrated tool storage to save space.
Want some extra blades?
Buy our 254mm saw blade package.
Add extra blades
The Perform PD254TS Saw Bench is a compact yet powerful solution for home workshops and DIY users. Its solid steel frame construction makes it easy to transport and store, perfect for those with smaller workspaces or mobile setups.
Despite it's compact size, the PD254TS is equipped with a 2kW motor that delivers smooth, consistent power for a wide range of tasks. A soft start feature ensures that motor powers up gradually, reducing noise while making the saw more user-friendly, especially in shared or residential environments.
This saw offers impressive cutting capacity, with a maximum depth of cut of 80mm at 90 and 50mm at 45. The rip fence allows for up to 300mm of cutting width, which extends to 650mm with the side table extension. With the extensions fitted, the total table width reaches 1,025mm, providing excellent support for larger workpieces. The rip fence locks at the front and back making it super rigid for accurate cuts. The coated aluminium table includes 19mm T-slots on either side of the blade, allowing mitre fences and jigs to slide smoothly for precise, controlled cuts.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table, for smooth operation.
Supplied with an adjustable mitre fence for angled cuts and a sturdy rip fence for straight, repeatable results, the PD254TS is well-equipped for a variety of woodworking tasks. A push stick is included for added safety and is housed within the integrated tool storage section. Two Teflon blades are included which help prevent resin build up; a 24 tooth ripping blade and a 60 tooth crosscut blade.
Dual 35mm dust extraction ports help to maintain a cleaner working environment when connected to a suitable dust extractor, and the fitted 230V plug means it's ready to go straight out of the box.
Please note, if you require an EU plug, please ensure you purchase 113504
Blade Tilt 0 to 45
Dust Extraction Outlet 2 x 35 mm I.D. / 42 mm O.D.
Max Depth of Cut @ 45º 50 mm
Max Depth of Cut @ 90º 80 mm
Max Width of Cut with Fence 300 mm / 650 mm with extension
Overall L x W x H 1,060 x 685 x 495 mm
Power 2.0 kW
Rating Occasional Use
T Slot Size 19 mm x 9.5 mm (3/4" x 3/8")
Table Height 325 mm
Table Size 560 x 680 mm
Blade Diameter 254 mm
Min Extraction Airflow Required 440 m/hr
Blade RPM 4,800 rpm
Plug Fitted UK 3 pin plug
Bore Size 30 mm
Max Ripping Width 300 mm / 650 mm with extension
Nett Weight 30 kg
Riving Knife Thickness 2.5 mm
Table Size With Extensions 560 x 1,025 mm (extended)
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142200
