All-in-one clamping solution
Built for a wide range of jobs, this heavy-duty clamp combines strength and versatility in one. With features such as hands-free clamping, tripod legs and a maximum clamping force of 1000kg, it's designed to handle everything from small clamping tasks, to serving as a portable workstation. Perfect for indoor or outdoor use, it’s reversible jaws, non-slip grip and portable design make it an essential tool for any workspace.
Perform quick clamp in yellow and black and in a workshop setting
Heavy duty construction
Made from thick gauge steel, it’s built to handle tough, heavy work. It can handle a maximum clamping force of 1000 kg.
A person outdoors in a yard supports a long wooden beam on a yellow and black Perform quick clamp
Hands free clamping
The Quick Clamp enables hands-free clamping, which is especially useful when securing large or heavy objects in the jaws.
Perform quick clamp stood on grass in front of a tree
Tripod legs
The three-leg design offers great stability, even on un-even ground – perfect for outdoor use.
Close-up of the jaws on a Perform quick clamp
Non-slip jaws
The clamp is supplied with non-slip, urethane jaws which helps to prevent slipping of material.
A man outdoors uses a yellow PERFORM quick clamp to support a large sheet of plywood while he cuts it with a jigsaw. The man is wearing safety glasses and a dark blue shirt.
Extra capacity
The jaws are reversible and have a maximum clamp capacity of 1,050mm, which allows clamping of larger projects such as doors
A close-up outdoor shot of a person's legs and feet wearing tan New Balance running shoes, standing on grass while adjusting a black metal tripod leg.
Footplates
Includes footplates for added stability using your bodyweight, when you have large, heavy-duty pieces
A man wearing safety glasses, ear muffs, and a blue shirt uses a yellow and black PERFORM mitre saw mounted on the Perform quick clamp to cut a piece of wood outdoors in front of a green hedge.
Multi-purpose
In addition to functioning as a clamp, it can also serve as a workbench for supporting other tools or projects, perfect if you have limited space or want to craft outside.
A person outdoors carrying a yellow and dark grey portable quick clamp on a paved surface, with grass and a building visible in the background.
Portable
Easily folds up for compact storage and hassle free transport, with wheels for added convenience.
Discover more easy work-holding solutions
The Perform Quick Bench lets you tackle jobs at home, in the workshop or on site with ease. Thanks to the quick set up, impressive strength and portability, it's perfect for use as a machine stand, worktable, or even for a car boot sale!
Find out more
The Perform Quick Clamp is a versatile and robust tool built to make clamping even more convenient. Constructed from thick gauge steel, it delivers impressive strength with a maximum clamping force of 1,000 kg, making it well suited for tasks in the workshop or outside. Its tripod leg design provides reliable stability, even on uneven ground-ideal for outdoor or mobile use where a flat surface isn't always available.
Designed for convenience, the Quick Clamp allows hands-free clamping via the foot pedal, particularly useful when securing large or heavy materials. The jaws are reversible and offer a generous 1,050mm clamping capacity, making it suitable for bigger projects such as door installations or to hold large panels. Non-slip urethane jaws help to grip materials securely, reducing the risk of slipping or surface damage during use.
Additional features include integrated footplates that enable you to apply bodyweight for extra stability when handling larger workpieces. Beyond its main clamping function, the Perform Quick Clamp also doubles as a practical workbench. It can support tools or serve as a stable surface for sanding, cutting, or assembly-especially valuable when space is limited or when working outdoors. The weight load is 300 kg.
Despite its solid build, the clamp is easy to store and transport. It folds down compactly and includes wheels for convenient movement and storage under a bench, in a van, or tucked away in a corner. The Perform Quick Clamp is an ideal portable, all-in-one solution for demanding clamping and support tasks.
Overall L x W x H 970 x 950 x 870 mm
Clamping Capacity 1,050 mm
Jaw Size 205 mm x 80 mm
Clamping Pressure 1,000 kg
Working Height 870 mm
EAN Barcode 5052511143276
