Durable, precise and easy to turn!
With no bevels to master and no sharpening required, this replaceable tip turning tool set is the perfect fuss-free choice for beginners.
A close-up action shot of a woodturning lathe in operation, showing a craftsman's hand guiding a metal cutting tool against a spinning light-colored wood blank. The background is a soft, out-of-focus yellow.
Durable and sharp
Designed with replaceable tungsten carbide tips, these tools offer extended life and maintain sharpness longer than traditional high speed steel alternatives.
A close-up of a person's hand holding a woodturning chisel against a spinning light wood blank on a yellow lathe machine.
Easy to control
Simply position the tool parallel to the floor on the tool rest, then move it smoothly along for precise control.
Three cutter profiles included...
The set includes; 11mm square cutter, 23mm round cutter and 10 x 28mm diamond shaped cutter for a range of different turning applications.
A close-up of a hand holding a small metal pin or rod above the tip of a metal tool, with fingers visible against a plain light gray background.
Simple maintenance
When the cutting edge dulls, simply rotate or replace the tip and you’re good to go again, there is no need to sharpen.
The Perform Replaceable Tip Turning Tool Set is a an ideal choice for those who are beginner turners, or those seeking durability and convenience. Each tool measures 330mm in overall length, providing a balanced feel that supports both precision and control during turning tasks. Designed with replaceable tungsten carbide tips (TCT), these tools offer extended life and maintain sharpness longer than traditional high-speed steel alternatives.
The set includes three cutter profiles to suit a range of turning applications: an 11mm square cutter for roughing and removing square stock, a 12mm round cutter ideal for curves and contours like the inside of a bowl, and a 10 x 28mm diamond-shaped cutter suited for fine detail work, tight corners and creating beads. The replaceable tip design simplifies maintenance - when the cutting edge dulls, simply rotate or replace the tip and you're good to go again; there is no need to sharpen. Easy to control, these tools sit parallel to the floor on the tool rest. Simply move across the rest to use.
The handles are made of smooth beech for a comfortable fit.
This set is well-suited for turners who are beginning their woodturning journey and makes an ideal accessory for the Perform PD240WL Woodturning Lathe. They are suited to smaller projects.
Overall Length 330 mm
EAN Barcode 5052511143115
