Start your woodturning journey with Perform
Whether you’re just beginning your woodturning journey or aiming to create smaller, more delicate pieces, the tommy bar–style Perform Woodturning Chuck offers a lightweight and reliable solution you can depend on.
A man wearing safety glasses operates a woodturning lathe, shaping a piece of wood on a yellow machine in a workshop. A large white dust extractor bag labelled PERFORM is visible in the background.
Perfect for beginners
Designed to be used alongside the Perform PD205WL Woodturning Lathe, this chuck is affordable and perfect for beginners looking to start their woodturning journey.
A close-up action shot of a woodturning lathe in operation, showing a craftsman's hand guiding a cutting tool against a spinning light-colored wood blank. The machine features a bright yellow body and a dark blue base with yellow lettering.
Compact
The 88mm chuck is compact, perfect for small turning projects such as pens, light pulls and small bowls.
A metallic lathe chuck with the brand name PERFORM visible on its side, displayed on a wooden surface alongside two metal shank tools.
Tommy bar design
The chuck uses a traditional tommy bar design, operated with two stainless steel bars to adjust the jaws and tighten the chuck manually. This simple mechanism keeps the overall chuck slim, to maximise the lathe’s capabilities.
Close-up of a metallic machine chuck with the brand name 'PERFORM' visible on its outer ring, attached to a bright yellow industrial arm against a soft gray background.
Stainless steel body
Chucks can be vulnerable to rust, which is why stainless steel is the perfect material choice. It resists corrosion and results in reliable performance.
A close-up of a turned wooden object mounted in a metal chuck on a bright yellow machine, photographed against a soft gray background.
Includes E Dovetail Jaws
Dovetail jaws are a universal jaw, providing a strong internal or external grip on the workpiece and are suitable for a variety of shapes and sizes; an excellent option for new turners. The Perform Woodturning Chuck is also compatible with a wide range of the Axminster Woodturning Jaws.
Made in Axminster, UK
Precision designed and manufactured entirely in Axminster, UK for accurate results.
Four woodworking chisels with light wood handles and silver metal blades, arranged diagonally on a wooden surface. The handles are engraved with the brand name 'PERFORM'.
The perfect partners for your lathe
Bring your Perform lathe to life with a set of turning tools built for beginners, or light use turning. Easy to handle and reliable in use, the range of Perform turning tools are an ideal way to start your woodturning journey with confidence.
Explore Perform turning tools
Interested in a course?
Discover the joy of woodturning from home! Our Woodturning for Beginners course teaches you the essentials—safety, sharpening, and turning techniques—while guiding you through two fun, step-by-step projects.
Learn more
The Perform Woodturning Chuck is a compact, reliable option ideal for entry-level and beginner woodturners working with smaller lathes. Precision made in Axminster, UK, it features a stainless steel body for added durability and corrosion resistance - making it a long lasting choice for those new to turning or those making smaller turned items. It is machined to exact tolerances for a perfect fit.
The 88mm chuck uses a traditional tommy bar design, operated with two stainless steel bars to tighten the chuck and adjust the jaws manually. This simple mechanism keeps the overall chuck slim, making it useful for smaller projects or delicate work, and to maximise the lathe's capabilities.
Supplied with black E Dovetail Jaws to give a stable and secure hold to your workpiece on both internal and external dovetails. These are suitable for a variety of timber shapes and sizes; a great universal jaw type. The chuck also features the quality SafetyJaw accessory mounting jaws - the edges have been modified with a slight radius, so if the jaws are extended beyond the body of the chuck, the chance of injury is minimised should hands get too close.
For woodturners starting out, this beginner woodturning chuck offers quality, control and simplicity. It is well suited to use alongside the Perform PD205WL Woodturning Lathe.
Designed, developed and made entirely in Axminster, UK for CNC accurate results. Suited to the Perform PD205WL Woodturning Lathe, the chuck spindle thread is 1 x 8 tpi.
Made in Britain Yes
Chuck Diameter 88 mm
Thread Size 1 x 8 tpi
Warranty Perform 1 Year Warranty
EAN Barcode 5052511143368
