This mitre gauge system is made from 5mm steel plate and features positive stops at 0, 22.5, 30, 45, 60, 67.5 and 90. Simple to adjust with a spring loaded plunger stop and able to be set at any other angle between 0-90 as required.
The other main feature is the anodised alloy fence, fitted with an adjustable flip-over length stop. This fence can be slid along the gauge body by releasing two thumb screws. The 320mm bar can be fitted to a standard 3/4 x 3/8 (19 x 9.5mm) table slot; the locking washer can be removed if required.
This mitre gauge will improve accuracy when cross or mitre cutting on many machines or router tables.
Web Attribute Set Router Jigs & Templates
EAN Barcode 5052511100408
