The UJK Sawhorses, a professional sawhorse sold in pairs, maximises your workspace versatility. These all-steel, folding saw horses are designed for versatility, convenience, and durability, making them perfect for site work. They are incredibly portable and compact, easily fitting into a van or workshop.
The legs fold neatly into the top rail and include carry handles, making them easy to transport and store. Setup is quick and simple, thanks to the quick-release button, allowing you to get to work efficiently. Unfolding the sawhorse reveals a material support arm at each end, which is easily adjustable for timber up to 45mm wide and 95mm high. Two hinged leg brackets hold sheet work in an upright position, for accessible cutting. The reinforced top prevents damage from accidental sawing, while the V-groove on top is perfect for round piece work. This versatility makes them ideal for various sizes of timber and tasks.
The adjustable height is not only handy but also allows you to work safely. The telescopic legs can be adjusted from 650mm to 825mm, enabling you to customize the height to suit your task. Whether you need a lower height for cutting timber or a higher one for other tasks, the UJK Sawhorse has you covered. The rubber feet ensure stability on various surfaces without scratching the floor, and the powder coating and zinc plating protect against corrosion, ensuring long-lasting performance in any weather. Additionally, the screw holes in the end pieces add rigidity, making the UJK Sawhorse even more reliable.
Each sawhorse can support up to 590kg, and together, they boast an impressive, combined capacity of 1,180kg. With the pair of UJK Sawhorses, two lengths of timber, and a suitable sheet of wood, you can create an instant, solid workbench, bringing your workshop to the site.
Manufacturer Part Number 1080SH
Model 1080SH
EAN Barcode 5052511138302
