The UJK Telescopic Trestle is built to deliver strength, precision, and versatility in equal measure. Whether you’re pairing it with the UJK Multifunction Workbench Mk II or using it as a standalone support, this is a trestle made to perform. Manufactured from robust steel for long‑term durability, the legs provide outstanding rigidity, while the top rails offer a perfect surface for accurate side clamping.
A smooth telescopic height adjustment mechanism and positive locking system make it quick and simple to set your ideal working height. The wide footprint, complete with rubber feet, ensures excellent stability on workshop floors, job sites, or when used outdoors. A lower rail adds convenient tool storage, keeping essentials close to hand as you work.
Designed to integrate seamlessly with the UJK Multifunction Workbench Mk II, the Telescopic Trestle brings premium workshop quality within easy reach - strong, stable, and exceptionally well made.
Specifications
Height range: 780–1,190 mm
Footprint: 660 × 685 mm
Maximum load: 200 kg
Can also be purchased as a pair under SKU 721044
Overall L x W x H 660mm x 685mm x 1,190 mm
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 5052511143337
