Made for removing light rust or tarnish and restoring a bright metal finish particularly to cast iron and steel. Garryflex is a block approximately 80mm x 50mm x 20mm made of a rubber like compound impregnated with silicon carbide abrasive particles. Available in coarse 60 grit (Blue), medium 120 grit (Dk Grey) and fine 240 grit (Brown). The blocks can be used dry but for best results use a lubricant such as water, paraffin, oil, camellia oil etc. (Do not use WD40 or similar as these tend to eat away at the compound). Garryflex blocks can also be cut to shape if necessary; the amount of elbow grease used with this product is entirely optional.
Garryson
Garryflex Abrasive Cleaning Block
| Abrasive Grit | 120 |
| Grade | Medium |
| EAN Barcode | 5052511116454 |
