The IRWIN® Blue Groove 4X Flat Bit Set is engineered to deliver fast, clean and efficient drilling in timber. Featuring a patented groove point and cutting edge that cuts rather than scrapes the wood, these flat bits drill up to four times faster than standard flat bits. The parabolic scoop design improves chip removal and provides greater control during use, while the increased relief angle of 17° enhances cutting performance. Each bit features a robust 152mm shank with a diameter 10% larger than standard for increased strength and durability. Supplied in a durable nylon storage case, this comprehensive 17-piece set includes the following sizes: 6, 8, 10, 12, 13, 14, 16, 18, 19, 20, 22, 24, 25, 28, 32, 35 and 38mm, making it ideal for a wide range of woodworking applications.
Irwin
Irwin Blue Groove 4X Flat Bit Set 17 Piece
| Web Attribute Set | Flat Bits |
| EAN Barcode | 5054905255213 |
