Kreg Micro-Pocket™ Drill Guide Kit 730 is an accessory for the Kreg Pocket-Hole Jig 720 and 720PRO, allowing these jigs to create compact pocket holes for smaller projects, thinner material and repair work. Producing pocket holes 33% smaller in diameter than standard, it is particularly useful when working with stock from 13mm thick and narrow pieces down to 25mm wide.
The Drill Guide Block simply fits into the Kreg Pocket-Hole Jig 720 or 720PRO. The stepped drill bit removes less material, making drilling quicker and requiring less effort, while the smaller pocket holes provide a neater solution for more delicate work. Designed for use with Kreg Pan-Head Pocket-Hole Screws (SPS).
Kreg is known for innovative woodworking solutions that help makers achieve stronger joints, cleaner finishes and more professional results with less effort.
Ideal for furniture making, smaller woodworking projects and repairs, the kit includes a Micro-Pocket™ Drill Guide Block, Easy-Set Micro-Pocket™ Stepped Drill Bit, Easy-Set Depth Adjustment Ring and Material Thickness Gauge with hex wrench. Compatible with Kreg Pocket-Hole Jig 720 and 720PRO.
