The Kreg Pocket‑Hole Jig 310 is a compact, portable solution for creating strong, accurate pocket‑hole joints in everyday woodworking projects. Designed to be simple to set up and easy to use, it’s well suited to both first‑time DIY users and experienced makers looking for a straightforward joinery option. The jig works with material thicknesses from 13mm to 38mm, making it suitable for common boards and plywood used in furniture, storage and general household repairs.
Preset material‑thickness stops for 13mm, 19mm and 38mm stock help ensure quick, repeatable setup, while the hardened steel drill guide delivers consistent accuracy. An included material thickness gauge and Easy‑Set drill bit with stop collar remove guesswork, allowing pocket holes to be drilled with confidence. The anti‑slip base keeps the jig securely in position during use, helping maintain accuracy without complicated clamping arrangements.
Built for durability, the Pocket‑Hole Jig 310 features robust construction designed to withstand regular use, with hardened steel drill guides backed by a lifetime warranty. Its simple, versatile design makes it equally suitable for indoor or outdoor projects, offering a reliable entry point into pocket‑hole joinery.
