The Kreg Pocket‑Hole Jig 720PRO is designed to help you build strong, reliable pocket‑hole joints with maximum efficiency. This advanced 700‑Series setup streamlines your workflow, delivering fast clamping, secure workholding and excellent material support for projects using stock from 13–38mm thick. With Automaxx one‑motion clamping, the jig locks your workpiece in place and automatically adjusts to the correct thickness, while the GripMaxx surface ensures nothing slips as you drill.
The included Docking Station adds generous support wings with built‑in storage and a repeatable stop, giving you greater stability when working with larger pieces. A dedicated Pocket‑Hole Jig Clamp lets you secure the jig to your bench so you can work confidently and consistently. When you’re finished, the wings fold neatly away, keeping your workspace organised.
A chip‑ejection port connects to your dust extractor to help keep the area clear, while the impact‑resistant body and steel‑reinforced spine ensure long‑term durability. Hardened steel drill guides come with a lifetime warranty, and on‑board storage keeps essential Kreg accessories within easy reach. To get you started straight away, the 720PRO includes 160 pocket‑hole screws and a ready‑to‑build project plan.
Web Attribute Set Pocket Hole Jigs & Accessories
EAN Barcode 647096810702
